Topic: Another Fireface ufx+ newbie q re Ch 11&12
I've got 10 of my inputs setup the way I want them but I'm having problems with front input 11&12. I'm trying to use regular line inputs but don't get a sound. When I press the Instrument button in Totalmix, there's a slight pop but no sound after. And the green Signal light doesn't light up. The channel meter # says UFL.
When I use the same instrument ins in 9&10 it works.
I should add the device is 2nd hand. So it might has some prior settings from prev owner that are not apparent to me. I did flash the drivers which were all somewhat out of date. And I think I did a reset correctly.
Thx!
