To be sure on this, do you have ADI-2 FS or ADI-2 DAC FS, two different products.
As you talk about EQ, then it can only be the ADI-2 DAC FS or ADI-2 Pro FS R BE.
For most flexibility I would
connect the ADI-2 DAC to a laptop or pc through USB, you can use it then as player or for streaming music. You need such a connection and an installed ASIO driver to be able to perform firmware upgrades which can happen from from time to time
put an Oehlbach Optosel 4:1 Mk II (https://www.oehlbach.com/de/audio-equip … l-4-1-mkii) in front of the ADI-2 DAC FS ADAT port. By this you can connect up to four digital sources to the ADI-2 FS. This Mk II version of the unit has a remote, looks good, not too expensive and supports up to 192 kHz. You can connect e.g. the Bluenode, TV, CD or BluRay Plased to it and either SPDIF or 1st two channels of ADAT.
I can recommend Mutec optical cables, look here: https://www.thomann.de/de/mutec_optisches_kabel_2m.htm, which allow even 15+1=16m between PC (RME UFX+) and ADI-2 Pro FS R BE in front of my HiFi. According to specs approx 10m is the max length, but never had an issue with 16m up to 192 kHz.Also good with Mutec, their optical cables have good plugs and not too stiff manteling which can be a disadvantage as they tend to loop formation and can then exert lateral tensile forces on the connector (like TOSLINK cables from Sommer Cable do).
Balanced / unbalanced connection to integrated amp
If your Mac is an integrated amp, then it's no problem to connect the ADI-2 DAC FS like any other device to one of it's analog inputs, I read it has unbalanced and balanced inputs. See also connection type 2 (red bullets) in the drawing below.
As the ADI-2 DAC FS supports balanced outputs I would use those as they are more resistant to any kind of noise, have a hotter signal and by this (both) supports much higher cables lengths like often needed in studio enviroments. But also Cinch cables are "not too bad", figure .. we lived with those for a very long time.
See also KaiS comment in post #3 below that your Mac seems to have integrated attenuators to prevent overloading the inputs and that you can use higher output levels at the DAC to make full use of the four reference levels which gives a 20dB wider range in terms of higher SNR/dynamik (at our listening levels "nice to have", but really not required for good sound).
Example Setup with TOSLINK switcher
My setup also uses these components in comination with an integrated amp:
PC---USB3---UFX+---ADAT(15m)----Port1+-Optosel 4:1 Mk II---ADAT(1m)---ADI-2 Pro---Accuphase E-600---B&W 803D3
BluRay----Port2+ "
TV----Port3+ "
Reserve(could be streamer)---Port4+ "
On the ADI-2 Pro I activated
- auto reflevel (see ch 12.1, also 31.12, 31.13 are informative)
- dynamic loudness (see ch 8.5, 12.4)
- Additional +3dB for Bass as usually I do not listen loud as well as you
- use of D/A filter "Slow" (ch 12.1, 31.3) as suggested by KaiS https://forum.rme-audio.de/viewtopic.ph … 68#p177168
- using B/T as needed, if some music material has a different mastering (more/less B/T)
- key remapping (ch 14.1.1): the four front keys I programmed with these functions
- toggle view (then you can use the remote to toggle between screens, e.g. between Dark Volume and Analyzer
- toggle Phones/Line
- toggle EQ+B/T+Ld on/off (quick deactivation of all EQing and loudness to listen to the original signal)
- toggle Mute (could be useful when being in front of the device)
Manual links:
https://www.rme-audio.de/downloads/adi2dacr_d.pdf
https://www.rme-audio.de/downloads/adi2dacr_e.pdf
Loudness
In my case the loudest output volume that I use on the ADI-2 Pro FS is -15 (dBFS).
I simply remember this value and use only volume levels below -15 that not to overload the preamp.
In your case this will be a different value.
To parametrize dynamic loudness correctly you need to substract 20db from your usual or highest listening level.
In my case -15 - -20 = -35 for the value "Low Vol Ref" under loudness settings.
That's it basically .. +/- a few optimizations, which are not really required as e.g. use of attenuator to maximize SNR/dynamic, which is high enough anyway and esp. at our listening levels.
Other sources of information
This blog article might contain the one or other interesting information for you, as well:
https://www.tonstudio-forum.de/blog/ind … ses-EN-DE/
Here a drawing that combines different aspects of these wonderful products
- how it can be used
- to be able to use the "Bit test, to have kind of an "end-to-end test" from player to DAC in the digital domain (see manual)
