Topic: DC Protection warning when streaming from local network and Line Out
I have the Adi connected to a Node over USB cable. I am using the line out connected to an Arcam amp.
I am getting this DC protection warning when I stream from a local storage - my PC.
The Node is not connected to LAN but just WiFi! This doesn't make any sense to me at all but it happens most of the time in the exactly same way.
I am usually streaming from Deezer and sometimes I use the locally shared Music folder from the PC. When I start the playback within 5sec I get the warning and all music stops. When I pause the playback it would remove the message within a couple of seconds.
How is it possible to have this issue when the Node is not physically connected to the PC in any way and it never happens with non local sources?
Amp: Arcam SA30
Speakers: KEF LS50 Meta
SUB: BK P12-300SB
