Topic: Problem about clocking UFX+ with Octamic XTC
Hi folks,
I'm using UFX+ connecting Octamic XTC via duplex Madi optical cable. And UFX+ as main clock sorce. I'm using Midi over Madi function to control XTC using MIDI Remote software.
When I changing the sample rate from 48KHz to 96KHz in UFX+ settings, XTC changing the sample rate itself, everything works fine.
But when I'm trying to change the sample rate from 96KHz back to 48KHz in UFX+, the XTC didn't follow. I can ONLY change the sample rate via MIDI Remote software.
Every device was updated to the latest version of firmware.
Is there something wrong with my settings? What should I do.
Thanks,
SeanYang
