Topic: Equalizer in Stand Alone Mode
Hi there,
Many RME USB interfaces have a stand alone mode. I know that I can apply an equalizer curve using TotalMix when the interface is connected to a computer. I am wondering: Can I alos use such an equalizer in stand alone mode? Could I configure the equalizer settings through a computer and then disconnect the interface from the computer and continue using the equalizer?
What I need is a compact device with two inputs for microphones and two line outputs. The device needs to provide phantom power for the microphones, apply a predefined equalizer curve and output the signal with low latency on the analog line outputs to be recorded on a video camera. I figured maybe an RME USB interface could do all of it?
Best regards,
Stefan
