Topic: Feature suggestion: Fine volume control on Babyface Pro with "Select"
[from the thread: https://www.forum.rme-audio.de/viewtopic.php?id=25509]
It depends on the fader position - around 0 dB it is 0.5 dB steps. The ARC USB will always work differently than the mouse or a hardware control. Nevertheless one feature is currently missing: holding down the shift key while turning the mouse wheel changes the step-size to fine mode. We will try to add this feature for the ARC USB as well.
I very much would like this feature with the volume wheel / encoder on the Babyface Pro as well. I tested if "Shift" on the keyboard works with the volume wheel. It does not. :-(
The logical choice would be to use the SELECT-button on the Babyface Pro.
Instead pressing SELECT on the Babyface Pro + rotating the volume wheel changes the panning. This is a function I do not need on the interface itself. It would be great to have the option in the ARC settings to choose if pressing SELECT + encoder will change panning OR will allow finer steps.
The latter I think will be more useful for most I guess!?
