Topic: Use more than one DigifaceDante
I'd like to use 2 of DigifaceDante as 96k/64Channels Dante/USB Audio Interface.
I had read 'Using more than one Digiface Dante is currently not supported. ' in a UserManual.
Will this be resolved in the future?
Re: Use more than one DigifaceDante
You can chain the 2nd Digiface Dante unit to the primary unit via the MADI coaxial connection. When used stand alone (no USB cable connected) the Digiface Dante works as a format converter for MADI <> Dante.
3 (edited by gelshx 2022-04-08 01:29:38)
Thanks for reply Jeff. I want to pre-timealign audio between Dante and MADI(from 2nd DigifaceDante Standalone) . Do I have to offset recorded tracks after recording?
In that setup the difference between both Dante streams should be a few samples only (3 to 6).
