Topic: [Solved] UFX+ not recognized by Surface Pro 4
Good morning everyone:
My DAW computer is in the shop and I am temporarily using my Surface Pro 4 (which runs Windows 10 64 bit). I installed the drivers and software and I can see the totalmix software panel, but it is not recognized. I can't switch from the internal sound card to the UFX.
Any thoughts / suggestions?
Peter
www.summeroflovemusic.com
https://www.imdb.com/name/nm2039241
Re: [Solved] UFX+ not recognized by Surface Pro 4
Did you install the USB driver? There is also a Thunderbolt driver, but this won't work when you connect with USB.
Yes I did (and the flash update as well), thanks.
4 (edited by MetalHeadKeys 2022-04-09 01:26:56)
Hello!
Have you set up a WDM Device?
In the Driver Settings Tab, under WDM Devices section, click on "Configure.."
There, you can set up I/O for Windows!
