Topic: RME FIREFACE UFX+ Analog inputs behavior
I am new to the RME family and got my first RME UFX+ :-)! Right now I am running the 3.27 driver for Mac M1 Studio Max, it seems to work with Logic. I am just in the beginning of finding my way through TotalMix FX but I am making slow progress.
Playback from the DAW works fine and I wanted to get myself around the mic preamps. I notice a fluctuation in the analog line in/mic levels, even with all faders down and no input. That means, I got movement fluctuation around -100dB on quite a few channels. Is it normal?
In addition to that, I also recognized that I was not able to bring the level of Mics 11-12 down when I turn the knobs on the unit. It doesn’t go further down as 8dB while levels of Mics 9-10 can be turned all the way down.
Is that normal? Or maybe I am a bit stupid ;-).
In the TotalMix FX video about routing the Mic inputs are called AN on channels 1-2 and with the Fireface the Mic inputs are channels 9 - 12, after the Line inputs. But I guess that’s the way it is, though I would expect Mic inputs right in the beginning.
I would appreciate it, if someone can help me.
Thanks a lot!
Frank
