Topic: Loose/broken ADAT ports in new Digiface USB
Hi all,
I've just bought a new Digiface USB, and have noticed that the ADAT ports are very loose. Does anyone know if this is common, or should I return it as a manufacturing defect? I'm testing a few different ADAT cables with it, and none of them feel like they properly connect on any of the ports. I've tried the same cables on a few other adat devices and they all have a very solid connection. By contrast, on the digiface I can remove them with the tiniest amount of pressure (literally the least pressure/force I can physically apply).
I know there are manufacturing discrepancies between ADAT cables, but can anyone confirm what the ADAT connection is like to the Digiface USB? I would have assumed I had a broken ADAT port, but I'd also find it strange to have an interface where all 8 ports have the same issue.
Any help would be much appreciated!
Best
James
