Topic: Subwoofer-Subpac & Headphone setup mix (UFX II)
hi guys! first post here
I finally got my RME UFX II interface, im so happy with this!!!
Im sure we will work on many, many productions in the coming years
This is my first RME, so im getting to know the TotalMix mix software.
The reason why i bought the interface is because i want to monitor through multiple outputs at the same time, and at the same time have a HP/EQ on the main monitor and headphone signals.
This couldnt be done in Cubase and other multiple out interfaces.
My setup:
UFX II
Windows AMD 5950x PC
Macbook Pro 2020
Subwoofer
Subpac (https://subpac.com/)
2 x Main Speakers
Heaphones
Bunch of synths
Bad Ears
Boatload of coffee
My goal is to have a HP signal on Main Speakers and Headphones, and control the volume with one slider/ARC/midi, while keeping all the low-end balance the same.
I also have to switch between ASIO and Windows all the time to A-B and Youtube/Beatport/Soundcloud etc preview.
How do i do this?
-My DAW signal comes from Cubase, i use the Control Room so i can only switch one monitor output at the time in Cubase.
-So now all my Cubase music goes to Output 1-2 in TotalMix.
-My subpac goes to AN 7/8
-Ive created a WDM driver and choose Analog 3+4 as device and speaker.
-This works, but cant find a way to adjust ALL the volume and keep it in balance, only from the apps i use. (like Cubase, mediaplayer, dj program, windows system sound slider etc etc).
What is the best way to connect all this?
Maybe there is a smart way to keep everything in balance and use one slider in Totalmix?
I cant find this in the manual and the routing videos do not talk about connecting subwoofers, or i cant find it.
Thanks! You guys are amazing
