Topic: ADI-2 Pro FS R AD/DA scenario, pls advise
Dear RME-ians,
Please could you validate my hypothetical use case?
I would like to set ADI-2 Pro FS R into AD/DA mode, but item 4 is an exception as it is A to D+A.
Following connections:
(1) computer via digiface USB optical out -> ADI-2 SP opt in + ADI-2 SRC on (for additional jitter removal) - -> ADI-2 main 1/2 out
(2) player device coax out -> ADI-2 SP coax in + ADI-2 SRC on (for additional jitter removal) - -> ADI-2 main 1/2 out
(3) other device AES out -> ADI-2 SP AES + ADI-2 SRC on (for additional jitter removal) - -> ADI-2 main 1/2 out
(4) analog player --> ADI-2 analog in --> ADI-2 main 1/2 out + ADI-2 digital SP opt out --> in order to record to digiface USB optical in
Few questions:
a. Does the above make sense?
b. And for programming the remote, could I without issues program above (1) thru (4) into key 1-4 on the remote control? I specifically ask because the manual says selection options are SP (not &opt &coax), AES, Analog etc but did not detail on SP opt and SP coax in detail
c. Will all this work in one mode that is AD/DA or does it require to switch modes?
