Topic: New ADI 2 Pro BE: No sound to any output from any input
I just received a new ADI-2 Pro Black Edition, and got it set up (with firmware updated first).
I have used the DAC version before (though not owned). I have not owned the Pro version. I use it at a home HiFi setup with the possibility that I might use the analog inputs in the future.
The device is recognized by a Mac via USB and shows up as an audio output target. However, it will not play back any sound sent to that interface.
The same goes for Optical input: There is no sound output from the device. The display shows no bars (that is, the connectors are not to blame).
I have tried both Analog XLR out and headphone out 3/4. Neither output makes any difference with either input. I have also checked that the device is not muted (for what I understand). I have toggled between DAC, USB and other modes. No effect. I have switched the source from auto to Optical to USB with no effect.
At no point do I see any bars or other signal activity in the volume display.
The device starts to warm up when powered on.
How should I troubleshoot? I have previously had the DAC version on loan and it worked out of the box with minimal setup changes. So I am somewhat familiar with the UI.
Thanks,
Tero
