Topic: Fireface UCX // Does not power up // Shuts down // Loose contact?
Hi!
I own the Fireface UCX. Great sounding piece of gear! I am having problem though that got increasingly worse over time:
It does not power up anymore without knocking on the casing. Usually it works then, but sometimes it pops off after hours of usage.
I have replaced the USB and power cable to rule out possible issues. Also, I applied contact spray to the pin sockets to rule out contact issues between the two boards. When taking the casing away, I noticed that a slight knock on the upper board turns on the UCX.
Do you have an idea what could be causing this issue? Are there typical components to look out for? I know well how to solder, but SMD is another degree of complexity. Should I get a lense to check for broken solder joints or what do you recommend me to do?
Thank you!
Re: Fireface UCX // Does not power up // Shuts down // Loose contact?
If nobody answers here, then I would suggest to write an e-mail to RME support. Did you do already?
Thanks for getting back! I just sent an e-mail to the RME support. I'll keep you updated for the sake of documentation.
Forwarded to service, looks like a hardware issue...
