Topic: Totalmix - Independent Fader Groups, for Remote Submix Control
I'm attempting to use my Fireface UFC+ as a FOH Mixer with 6 separate monitor mixes for the musicians, via Totalmix and Totalmix Remote. In addition to the various instrument and vocal inputs, I have multiple keyboard and drum inputs that I'd like to show up in the individual monitor mixes as two single Keyboards and Drums faders, rather than each of the musicians having to adjust all the various inputs.
I had high hopes that I could set up two fader groups, for Keyboards and for Drums, such that the individual groupings would be common for each Monitor Submix, but the adjustable levels would be independent for each submix that the Fader Group was assigned/programmed to. In this way, I could establish a basic mix for Keyboards and Drums, and each user could then have a single adjustment point that would let them independently adjust their desired volumes of each "input submix". As I've discovered, the Fader Groups are not independent, such that programing the same fader group across more than one output submix causes level adjustments that impact/corrupt the other submixes. So, I've given up on that approach.
If there were a larger number of assignable Fader Groups, I would be able to accomplish my goal, but with only 4, I can only get 2 of the 6 musicians the simplified interface. But in lieu of that, the only way I've thought of to accomplish my goal is to use a hardware/cable output to input loopback: for example, it seems like I could break my AES HW Input & Output into two mono sends and receives, and build a Keyboard Submix for one and a Drum submix for the other; then with the output hardwired back to the AES input, I could then use those 2 inputs as the single point Keyboards and Drums inputs in each monitor submix. My main concern there is the potential feedback if the AES outputs hever had the inputs brought to non-zero values.
So I'm looking for some comments as to the viability of doing this. Perhaps there is another more direct way to accomplish what I'm trying to do that has escaped me? Suggestions and comments welcomed!
Also, to the RME mods, would my suggestion to make the 4 existing Fader Groups "independent" over each output submix be an enhancement that might be considered viable for future Totalmix updates? It would obviously be helpful to someone using the Remote user features, but I imagine a lot of folks using Totalmix don't run at that level of complexity. Having a new Preferences selection that would toggle the feature on/off would be ideal.
Thanks for your consideration!
Dave
