You need no blower, simply leave some space between the components so that heat does not pile up and that you have a little airflow on the top and the bottom of all devices.
For RME devices I am using Thomann Eco compact racks with 23cm depths, for three devices I use a 4RU rack at minimum for that purpose. With 23cm the rack is not too depth so that you get a good airflow.
https://www.thomann.de/de/thon_3he_compact_rack.htm
For the devices with more depth like e.g. a Lexicon PCM91 I am using a similar rack with 35 cm depth. This is planned for two devices, so here also 1RU more.
https://www.thomann.de/de/thon_rack_3he_economy_ii.htm
