RME tests up to three devices for their drivers, theoretically even more are possible, but not tested.
In terms of clock synch you can chain it through ADAT.
PC------USB------BBF1 clock master
ADAT OUT
ADAT IN
PC------USB------BBF2 clock slave, gets clock via ADAT IN from BBF1
ADAT OUT
ADAT IN
PC------USB------BBF3 clock slave, gets clock via ADAT IN from BBF2
I showed here only the TOSLINKs important for clock synch, of course you should also connect TOSLINK cables for the other transfer direction for audio.
Each interface has a TM FX instance of it's own. So you can't simply route e.g. a HW input of BBF2 to HW output of BBF1 in terms of the digital routing matrix of each device, this is a fix boundary. But you can of course route up to 8 channels through ADAT at single speed or 4 channels at double speed, etc.
