Frank007 wrote:ramses wrote:Better would be to get a RME recording interface with TotalMix FX
- expand it with the ADA-8200 and
- finally, add the ADI-2 Pro to enhance your monitoring section
Thanks for your answer… I assumed, with the ADAT inputs and outputs, I could get 8 extra ins and outs. But this isn't the case? Because compared to my Apollo twin the sound really good so can't go back… I'm still able to return my unit and change it to a different model. What would you advise?
I would base a recording solution on a recording interface with TotalMix FX. This gives you the required flexibility in terms of routing, loopback operation, operation in general.
Such a solution you can expand by adding preamps and AD/DA converter via ADAT, AES, MADI, etc ..
The ADI-2 Pro you can add to enhance e.g., the monitoring section, see also my blog article how to integrate this into your solution, incidentally … I gave you already a few examples above.
I am using myself a similar solution, at the end the same concept
PC---ARC USB
UFX+-----------ADAT1 OUT------ADI-2 Pro FS R BE (recording corner)--------------------------------------------------Monitors/Phones
| | \----------ADAT2 OUT-----------------------------+Optosel 4:1 Mk II------ADI-2 Pro FS R BE (HiFi corner)-----HiFi
| +---12Mic Blu-ray---/
| +---Octamic XTC TV--------/
(MADI)
