Topic: Hdspe madi fx no input sound when recording in Logic Pro x
Any idea someone
I have been trying hard…
Big sur/hdspe madi fx/ ax32 DAD/Logic Pro x
All latest drivers installed
I get output from logic on channel 1/2
I see madi output in ax32 matrix on channel 5
Logic input is set to madi 5 on recording track
I get output signal on 1/2 software playback in total mix
Thx for helping
Re: Hdspe madi fx no input sound when recording in Logic Pro x
Make sure you have granted access to Microphone in the Mac System Prefs > Security & Privacy > Privacy tab. In Mac OS, Microphone means "audio input". All your DAW apps and TotalMix FX require rights for Microphone.
Thx will try!!!
Will let you know
Thx will try!!!
Will let you know!!
Hi jeff
Just tried to do that and I can’t see total mix effect in security/privacy /privacy tab/microphone
I tried reinstalling the driver (without uninstalling it)and still I can’t see total mix in there (privacy tab/microphone
Any idea how I can fix this
Thx for your time
TMFX only shows here for MADIface Pro and Babyface Pro, IIRC. These only use it for the reverb FX.
What about your DAW apps, did these have a checkbox?
Hi jeff
I found out that on Mac OS Big Sur, I have to reset the driver by writing a script in terminal…
Will try that when I can…
Hi jeff
Hi
Tried the drivers permission  reset in Mac OS terminal in recovery mode….
Still can’t see rme total mix app in microphone/security/privacy after allowing it in security/privacy
Please help me rme
I’m about to return my hdspe madi fx card as after spending 2 days trying to get it working I’m starting to get desparate
Thx
Does Totalmix open normally? Does playback work?
Hi daniel
Yes total mix opens normally
Playback works
I can’t see total mix in microphone/security/privacy/preferences in max os big sur…
I have been trying to do a rme driver reset as per the rme video (rme.to/reset) in the terminal without any success….I do allow it in security/privacy/general when prompted and still don’t see it in the security/privacy/microphone pane
This is why I suspect I can’t record in my daw
Please help me
Mario valiquette
Should I try uninstall the driver before trying to reset again
Does your DAW have access to the microphone? Have you tested other software to record, e.g. Reaper?
