Topic: Possible to use stock XLR->TRS cable for unbalanced connection?
I need to connect a guitar pedal to UFX+, HW output Analog 1/2 (the output with XLR connectors).
Not 100% sure, could I use a stock XLR -> TRS cable for such an unbalanced connection?
Any negative side effect?
BR Ramses - UFX+, 12Mic, XTC, ADI-2 Pro FS R BE, RayDAT, X10SRi-F, E5-1650v4, Win10Pro22H2, Cub12Pro
Re: Possible to use stock XLR->TRS cable for unbalanced connection?
As mentioned in the manual - Pin 3 should be disconnected as chances are that R will be shorted to GND within the peadal.
3 (edited by ramses 2022-09-19 12:29:16)
Thanks, Matthias.
Am I right in thinking that it is safe to just try it out?
If something shorted out from the pedal, would it be noticeable?
A poorer quality would be unfavorable if you would notice it later.
I expect the pedal not to need full/max level, that would help with distortion, and yes, nothing will break, so you could try it.
