Topic: UFX+ clocking setup with 2x ADAT AD & 1x MADI AD/DA
I'm running a UFX+ as my main interface, with 2x grace m108 (8x mic pre) AD over ADAT and a 16ch Ferrofish Pulse AD/DA over MADI.
The UFX+ is the clock source, with everything syncing over either ADAT or MADI, no wordclock BNC.
Is this the optimal setup? ..or should I be syncing the two ADAT units to the UFX+ via wordclock?
Also, since this ADAT setup is limited to a sample rate of 44.1/48. Would it be worth trying to connect one of the Grace units using both ADATs (SMUX2) for a 96khz sample rate and then use the 2x available ADAT ports on the Ferrofish (MADI) unit for the 2nd ADAT unit (also in SMUX2).. ?
I assume in that situation I'd want to sync the connected units via wordclock..?
