Topic: ADI-2 PRO FS R Headphone correction software
Primary using the ADI-2 pro fs r for music production, monitoring, mixing, and mastering purposes. I primarily use headphones to mix and master following in the footsteps of renowned mastering engineers such as Glenn Schick who masters 100% in headphones and in the box. With the ADI-2 pro fs r ability to set EQ curves and Crossfeed emulations internally, I should be able to do away with headphone correction software such as Sonarworks and Goodhertz Can opener. I really wish there were more videos and tutorials geared at engineers who use the ADI-2 pro in this way. It would be nice if there were a way to copy headphone correction curves from Sonarworks directly into the ADI-2 pro for a flat frequency response for mixing. I tried manually doing it by pulling up the curve on the software and visually trying to match it up on the ADI-2 pro. It sounded close but not close enough for me. I'm also currently researching the 5 crossfeed effect built into the ADI-2 PRO FS to see which is the best one for mixing and mastering in headphones. If anyone had any experience, thoughts, or ideas on this matter id be happy to hear them.
