Topic: Nothing working....Digiface USB
I powered up my system this morning and was not greeted by TotalMix as normal.
I manually opened it and no mix window came up..the app is running however.
I then opened my Fireface USB settings and it is showing my input status for all 4 inputs blinking from Sync to Lock and had the Sample rate at 32k, instead of 48k.
It shows the current firmware as v14 and shows the serial number of the Digiface so some communication is active.
My four interfaces are Arturia Audiofuse 8 pre's....all of which are running fine individually when I connect them direct via USB and all have been the latest firmware for a year.
I had updated my Mac to 11 a few weeks ago (and the system has been perfectly fine, running all DAWS as well as standalone with Totalmix).
My System
Mac OS 11.7.1
Total Mix 1.78
Fireface settings 3.28 (5)
Digiface Firmware v14 (tried to update but clicking update does nothing)
any ideas why no Totalmix and the sync lock issues and not being able to update the Digiface all of a sudden?
Re: Nothing working....Digiface USB
Sounds like the usual Big Sur driver bug again, just reinstall the driver or try the beta version here:
https://forum.rme-audio.de/viewtopic.php?id=35957
3 (edited by fieldstu 2022-11-02 00:43:56)
The 32khz clock in my experience appears when the df usb is set to synch to an ext clock. When the ext clock is offline and df usb is restarted that 32khz clock freq seems to appear
ADI2, Digiface, ARC
Thanks Jeff, the beta driver did fix it.
