1 (edited by acwell 2022-12-16 18:44:08)
Topic: Babyface Pro IN3 Input Issue
Hardware :Babyface Pro FS
Driver version 1.219
Firmware:201
System:Windows10、11、Mac OS13
Recently,I found some problems withe the input IN3 on my Babyface Pro FS.When input a sine wave scan Frequency(20Hz-20kHz),IN3's frequency curve like work in very slow roll-off  FIR filter?High frequency drops very fast.
I conducted a replacement analysis of different output devices,OS,Plugs.I confirm the Bugs or Problems just on IN3 input.
I don't know if it's because of new Firmware?or Hardware Issues.
Thank you for help!
Re: Babyface Pro IN3 Input Issue
May you provide comparison fotos Input 3 and Input 4 ?
Yes I have photos, but no image host.May I email attachment?
Try onedrive pic host
screen capture from Audition
https://1drv.ms/u/s!AkAUjPVRQfO_3UwrS8h … -?e=mpWv6a
and .wav file
https://1drv.ms/u/s!AkAUjPVRQfO_3U6OeBi … B?e=kISwd0
You recorded a sine sweep and it looks acurate as it should.
Nothing to complain.
where is the issue ?
That is your wave looking :
https://ibb.co/KbgQRFB
The issue is right in front of your eyes - the left channel looses amplitude (level) at higher frequencies, while the right channel stays on track.
I am still not sure what that means exactly, as this sweep is hard (or cumbersome) to analyze. Also I see a lot of aliasing, so I wonder what was done here exactly.
There are many free tools that let you analyze the frequency response and give a plot that makes it easy to see any issues. Better use those.
7 (edited by acwell 2022-12-18 06:57:51)
L=IN3
R=IN4
Two signal is same(or switch plug)but recorded is different.I think it's the new Firmware's bug.The new Firmware maybe let IN3's A/D work at the different FIR filter.
It's not software's problems.
9
I tried to analyze your sweep file. There is no filter in the ADC that would result in 3 dB loss at already 20 kHz when using 96 kHz sampe rate. The slowest filter would have 3 dB at 40 kHz then.
So did you swap the cables between 3 and 4 to verify that the error is not found on 4 then?
