Stojan wrote:yes, I see the playback signal, everything seems to be in order...only there is no sound. phones 1,2 etc is set to none. I have tried various settings, but it simply does not work. Today I will try on my laptop. If that will not work, Then I assume the box has to go to a repair shop.
In TotalMix you have to select the hardware output for the headphones (on Fireface UC these are out 7-8), then open the software playback fader. Depending on your TotalMix settings, this works different:
- submix mode (to select in blue area top right): click on hardware output for headphones, then open the playback fader where the signal from your DAW comes in
- free mode: go to the software playback channel where the signal from your DAW comes in, click on the bottom where you see small channel numbers, for ex. AN 1-2 to select the right hardware outputs for the headphones
If you have assigned the headphones, this stereo channels appears on bottom right, control room section.
FF 400 - Babyface pro - Digiface USB - ADI-2 (original)
