Topic: RayDAT sample rate defaults / changes to 44.1 on system startup
Hi - I just recently purchased a RayDAT, which I am using in a Sonnet Echo Express I enclosure - hooking up to my MacBook Pro M1 Max system.
The interface works flawlessly - except for one problem I am having. Every time I shut down my system and start back up, or unplug the RayDAT and plug back in, it defaults to 44.1. I work in 48khz, so it's a hassle to remember to manually switch it back every time in the HDSPe settings. Once I switch it, everything works fine for that session while it is connected. The RayDAT is set as the master clock for all connected devices, and everything syncs properly.
My UCX II does not have this same issue. Once I set it to 48khz, i can disconnect it / restart my system, and it stays at 48khz when I start back up.
I have the latest drivers installed for RayDAT, and all of my settings in Audio / Midi are set to 48khz (not sure if this affects anything).
Does anyone have any insights? My goal is to have the RayDAT stay at 48khz so I don't need to manually change it every time I start up my system. Thank you!
