Hi Jonathan.
Congratulations that it works now.
Just by the way. If you plan to work more often with the matrix view, then I would delete all unnecessary routings.
Thereafter, you will find your way around the matrix view much better, and it will be much easier to validate even more complex routings.
To put an example: recently, I completely rebuilt my setup after many years:
https://forum.rme-audio.de/viewtopic.php?id=36025
It went easier than I thought, and now the matrix gives me the overview I was hoping for, so I can use it better for validating settings. Before, the preset (but not needed) routings robbed the overview (especially with a UFX+ with many channels).
Note: the complete deletion of the TM settings described in the posting is only worthwhile if you want to create a complete default setting. So, not only regarding the routing, but also the channel layout (folding of channels).
For you, it is easier as you are at the beginning and did not perform so many changes. In your case, you can, e.g., perform such steps:
- to delete all routings in the Matrix view with Ctrl-LeftMouseKey,
- to add only the necessary routings (I think easiest to be performed in the Mixer view in submix mode) and
- to check them in the Matrix view, finally.
As a side note: this action resulted among other things in further interesting findings / feature requests for TM FX, which I have collected here: https://forum.rme-audio.de/viewtopic.ph … 45#p192345
You are welcome to add a "+1" so hopefully RME will implement some of the suggestions.
But as the saying goes, Rome wasn't built in a day either. You don't have to implement everything immediately. I was just surprised that you have already discovered and used the Matrix View, and wanted to give you an outlook on how you can open up and optimize the environment step by step.
In this post, you can see that after that, I also started to use the matrix view for documentation purposes:
https://forum.rme-audio.de/viewtopic.ph … 00#p192400
Tip: on Windows, you can use the screenshot tool "Greenshot" to add additional documentation notes easily and quickly.
