Topic: Babyface Pro FS crackles on macOS when Parallels machine is running
Hi, I have a Babyface Pro FS (Firmware: v200, Driver: v3.27) connected to an M1 MacBook Pro (16-inch, 2021) running macOS 12.6.3 (Monterey). My Babyface plays fine until I run a Windows 11 virtual machine in Parallels. When the VM is running (Babyface still connected to the host machine, not virtually to the VM) every few minutes I get audio stutter and crackle. When I stop the VM, the problem goes away. The issue does not happen with the built-in soundcard.
Does anyone experience the same problem?
Is there a possibility it will be better with driver v4?
Is there something I can do about it?
Is there something RME can do about it?
Thank you! :-)
