Topic: Babyface Pro FS crackles on macOS when Parallels machine is running
Hi, I have a Babyface Pro FS (Firmware: v200, Driver: v3.27) connected to an M1 MacBook Pro (16-inch, 2021) running macOS 12.6.3 (Monterey). My Babyface plays fine until I run a Windows 11 virtual machine in Parallels. When the VM is running (Babyface still connected to the host machine, not virtually to the VM) every few minutes I get audio stutter and crackle. When I stop the VM, the problem goes away. The issue does not happen with the built-in soundcard.
Does anyone experience the same problem?
Is there a possibility it will be better with driver v4?
Is there something I can do about it?
Is there something RME can do about it?
Thank you! :-)
Re: Babyface Pro FS crackles on macOS when Parallels machine is running
Test with driver 4 is easy to do and go back to the one you use now is no problem.
Very exotic problem, it seems to be Paralles has a bad influence onto the mac ?
Sadly, installing driver version 4.06b did not help.
Once the VM puts some load to the CPU, macOS playback through Babyface starts to stutter. When I change sound output to the built-in audio, it plays fine.
I'm just trying to listen to music on my Mac while working in Visual Studio on a virtual machine in Parallels.
For just running an EXE in Mac I use the app PlayOnMac, it's a simple Windows Emulator for running exe without fully load a Windows. Its fast and smooth. I don't use Paralles anymore.
5 (edited by nixx 2023-08-24 11:19:55)
Problem solved by installing macOS Sonoma Beta.
It wasn't caused specifically by Parallels but rather by high memory pressure. Sonoma handles high memory pressure without external USB audio interfaces stuttering.
