Topic: Implementing BabyFace Pro to my Fireface UFX-II - best approach
Currently my only audio interface is RME Fireface UFX-II (running happily under Big Sur).
The analog INS and OUTs of the Fireface UFX-II are all used and I want to add one analog unit with 2 x XLR inputs and 2 X XLR outputs.
Since I have the Babyface Pro next me, I was thinking to use it as additional I/O for the external analog unit (mastering EQ+compressor)
I think that I could do that in 2 way:
1) Power the Babyface Pro externally (but not connected to my computer via USB),
connect the Firface UFX-II and Babyface with 2 ADAT cables,
and use the Babyface Pro as A/D/D/A convertor.
or
2) Connect the Babyface via USB to my computer (not use the ADAT connections) and
create an aggregate device in my computer containing the Firface UFX-II and the Babyface Pro.
I would like to know if my thinking is correct at all and
if it is what would be really the best way to go.
RME Fireface UFX II, RME ARC USB, ADAM Audio, Big Sur, DP, VEPRO, Cubase 13 Pro.
