Topic: A quoi ca sert ?
Je possede un RME ADI 2DAC FS, a quoi me servirais le DIGICheck ? quel est son interet ?
LINN AKURATE DS, LINN UNIDISC SC,AMPLIS MCINTOSH C300 et MC7106 + RME
Re: A quoi ca sert ?
Digicheck consiste à regarder le signal
M1-Ventura, Madiface Pro, Digiface USB, Babyface silver and blue
Comment trouver la derniere version pour windows
4 (edited by ramses 2023-03-07 13:48:57)
Bonjour, juste une suggestion. Que penses-tu de l'utilisation d'un traducteur gratuit. Il est tout de même plus efficace de confier la traduction à une seule personne plutôt qu'à "n" personnes qui lisent le texte. De cette façon, beaucoup plus de personnes liront et répondront le cas échéant.
Hi, just as a suggestion. What do you think about using a free translator? It's more efficient if only one person does the translation work than "n" people reading it. Then a lot more people will read and respond.
--- > https://www.deepl.com/translator
See also: https://forum.rme-audio.de/viewtopic.ph … 67#p198867
BR Ramses - UFX+, 12Mic, XTC, ADI-2 Pro FS R BE, RayDAT, X10SRi-F, E5-1650v4, Win10Pro22H2, Cub12Pro
In English
Where can I find the latest version of DIGIcheck for Windows and will it allow me to view the signal from my RMA ADI 2 DAC FS?
6 (edited by ramses 2023-03-07 18:58:28)
Many thanks Eric, English makes is much easier for me.
This is the download link where you can download software (see pull down menu on the right side):
https://rme-audio.de/downloads.html
Here is the direct link to latest DIGIcheck software: https://rme-audio.de/downloads/dc_596_win.zip
You have to install the MADIface ASIO driver for the ADI-2 DAC/Pro * as well,
because DIGIcheck needs it to access the interface:
https://rme-audio.de/downloads/driver_m … _09808.zip
I downloaded the software and the driver without any problem
I launched my RME ADI 2DAC FS, but nothing happens (the audio scope and the spectral analyser show nothing)
8 (edited by ramses 2023-03-07 20:39:37)
Did you install the MADIface ASIO driver?
After opening one of the DIGIface Windows, did you open "Options" menue and select "Input device setup" ?
There you need to select the ASIO driver and the playback channel.
