1 (edited by atmirza 2023-03-15 06:06:44)
Topic: MADIFace Pro, UFX III, and 12mic for remote recording rig?
I have a MADIface Pro and 12 mic, connected via MADI optical. Works great. I do some remote recording where it's useful to set the 12mic on stage and then run 100 feet of MADI to the MADIface Pro and laptop in a separate room. Then the MADIFace Pro itself is great on its own for simpler remote recording and performance projects.
I've been waiting for the successor to UFX+ so I can add more I/O.
Now that it's here, what I'd like to do is stack a UFX III and 12 mic in a 2u enclosure to use in my studio and also as a flexible stage box for remote recording/performance, with the MADIface Pro as my interface.
Before pulling the trigger, can someone confirm that this setup will work--basically that I can use the UFX III as a standalone MADI device?
Here is the chain:
Laptop (USB)  <---> MADIface Pro (MADI optical out) ---> UFX III (MADI out) ----> 12 Mic (MADI optical out) -->  MADIface Pro
I guess I wouldn't have access to Totalmix FX, since that is not available on the MADIFace Pro, but that's ok.
I haven't used DURec but I would like to. If I understand correctly, I would have to manually start/stop recording directly on the UFX III rather than via Totalmix.
Anything else I should consider?
Re: MADIFace Pro, UFX III, and 12mic for remote recording rig?
User manual page 52 says yes.
M1-Ventura, Madiface Pro, Digiface USB, Babyface silver and blue
Right. Thanks waedi.
Here is the chain:
Possible and you can also use ARC USB for starting and stopping DURec.
You can also connect a small laptop to control via TM FX at the device and if there is a LAN or WLAN you can use this to remote control TM FX using TM FX remote by a much smaller tablet alike Windows device.
You can also use TM FX for the iPAD to control the UFX III.
BR Ramses - UFX III, 12Mic, XTC, ADI-2 Pro FS R BE, RayDAT, X10SRi-F, E5-1650v4, Win10Pro22H2, Cub12
Good suggestions, thanks.
An iPAD would also allow me to set things like monitor mixes at the UFX III.
