1 (edited by Chris H 2023-03-29 20:55:34)
Topic: Driver and TotalMix seems happy but there is no sound
Fireface UFX, MacOS 13.2.1, driver and firmware updated.
The driver is recognized and totalmix behaves normally. There is signal on playback channel AN1/2, and it can be routed to output channels.
The only problem is that there is no signal on the physical outputs. And when I put a signal on a physical input, it is does not show up in TotalMix.
I have tested on a windows computer with same result.
I hope someone has an idea of what I'm doing wrong :-)
Re: Driver and TotalMix seems happy but there is no sound
Did you connect XLR cables from analog output of the UFX to XLR AES inputs at the monitor speakers ?
Did you lift-up the output channel faders in Totalmix ?
Sure that output channel is not muted ?
Try headphones ?
I don't use XLR.
I lifted all channal faders, and tried diferent outputs. Including headphones.
I tried direfrent assignments.
No channels are muted
Chris H wrote:
I don't use XLR.
Can you do a screen dump of tmfx, with sound coming in please?
Babyface Pro FS, MSI GS66, Studio One
5 (edited by Chris H 2023-03-29 21:44:53)
Screen dump: https://www.dropbox.com/s/kcfg9y9oajb2w … 6.png?dl=0
6 (edited by waedi 2023-03-29 22:06:50)
From the user manual :
Possible causes for a Fireface not working
• The FireWire or USB cable is not, or not correctly inserted into the socket
Driver installation and Settings dialog/TotalMix work, but a playback or record is not possible
• While recognition and control of the device are low bandwidth applications, playback/record needs the full FireWire transmission performance. Therefore, defective FireWire cables with limited transmission bandwidth can cause such an error scheme. The same is true for USB cables.
How do you connect the unit, with Firewire or USB ? not both
In the screenshot all inputs are non-functional. Looks like a failing power supply to me, I think your FF UFX needs service.
Could the power supply have gone when the VU meter on the FF is active? On the other hand... when I send signal into a physical channel the VU-meter on the FF does not move.
9
A power supply does have multiple voltage rails. Here the +5 V for AD and DA conversion seem missing.
That sounds reasonable. One more try. The faders in Mac Audio Midi Setup does not respond to how the faders in TotalMix are set. See Screen dump. https://www.dropbox.com/s/xlp82f70mjjjq … 5.png?dl=0 Doesn't that indicate a driver problem?
This device is defective, sorry. All the analog inputs are showing "UFL", which means no AD conversion happening, and it seems DA is also dead. This will require service.
Thank you for your help.
Best!
\c
