ruff wrote:KaiS wrote:ruff wrote:Thanks for the quick reply. I already activated it and it does allow me to set different EQ settings for L and R but not Bass/Treble, if I boost the "B B" or "B T" on the right side it changes the left side to the same value, I can't set them to different values.
Try (too lazy to check by myself):
EQ / EQ (2nd press) / ...Out... / Load B/T w. Preset: ON
Be sure to have the latest firmware installed, there were changes in this regard.
Load B/T w. Preset is ON, it's weird, because I'm pretty sure I was able to set them separately for L and R in the first few days I had the device and then something happened where it won't work like that anymore. And I'm on the latest firmware.
Are you setting Bass / Treble in the EQ-window, where you find BB (= Band-Bass), B1, B2, B3, B4, B5, BT (= Band Treble)?
In the “I/O / Bass/Treble /... “-menu they don‘t split left-right, I think.
EDIT:
I just checked, bug (?) or intentional:
Bass / Treble does NOT have individual left/right, “Dual EQ” settings.
