dartrayne wrote:Catalina 10.15.7
driver_usb_mac_3222a
Thanks.
When I press play and press stop after some time it 'freezes' for 3 seconds then it works. Cpu meter shows overload.
Well, if there is an actual CPU overload, that's possibly a Live issue. That would be rare for a driver to cause a cpu overload. Especially if you have a loop active as I've noticed CPU overloads in Live when going from the end to the start. The question is why this happens, but you should talk to Ableton support as well. I do recognise this and similar issues, but I never think I got to the bottom of it. I don't have it now.
Have you noticed if you create a test set, that if you remove any plug-ins or switch instruments this kind of symptom goes away? If so, could certain plug-ins/devices be involved?
Does this happen at any load capacity? 25, 30, 45 or 50%? What is running in the background when this happens?
What happens if you set the Babyface into class compliant mode? Does that change anything?
Also, you say this doesn't happen with internal audio. But what are the actual latencies if you compare them? If you set internal audio to the same latencies as when using the Babyface, is this still true?
RME Babyface v226 | 4.07 | MacBook Pro 13" 2020 | 16gb/1tb
