Topic: Performance Issues (Babyface / Driverkit / MacOS 12 / Pro Tools)
Hi all -
I've been having poor performance under MacOS 12
Pro Tools drops out of plan or exhibits buffer issues.
If I change to any other audio interface, it works fine.
If I change back to Babyface, it's bad.
It does pass audio, but not consistently and I get stops and glitches often enough I can't get work done.
Steps taken:
- reinstall drivers
- did full rebuild of all Pro Tools prefs etc, though this seems not the issue (as PT plays fine e.g. with headphone out; anything except Babyface is fine.)
Steps NOT tried:
- reverting to KEXT driver
Babyface (original) currently up to date on Firmware v226, DriverKit Driver 4.08
Pro Tools 2023.3 running in Rosetta mode.
-jeremiah
1: MBP M1 Max 64gb
2: 2018 i7 Mini, 32gb
ProTools 2023.3, Live 11
UFX, FF400, Babyface
Re: Performance Issues (Babyface / Driverkit / MacOS 12 / Pro Tools)
A little further:
- glitches in audio also exhibited in other software.  Ableton Live for instance.
- Seems to have started with OS update to 12.6.5
-jeremiah
1: MBP M1 Max 64gb
Further:
- reinstalled the latest KEXT driver (made no attempt to uninstall DK driver first)
- still glitching.
Result:  Babyface not usable on this system at this time.
note:  after installer run (with reduced security per instruction) I was *not* presented with the grey “allow” button in the General tab of Security and Privacy prefs. I’ve previously had the KEXT installed, so perhaps the permission is preserved?
-jeremiah
1: MBP M1 Max 64gb
Why not update the MacOS ?
MacOS 12.6.5 is already the latest security update for OS12.
Not ready to transition to OS13 yet;  I tend to stay on the trailing edge of OS updates, to keep my systems happy / more stable.
Are you proposing I *reinstall* the OS?
-jeremiah
1: MBP M1 Max 64gb
On my computer MacbookAir M1 with Ventura 13.3.1 Logic and Reaper playing fine, no stutter glitches dropouts, no issues, RME driver 4.08.
That's why I mentioned the OS upgrade.
I never did reinstall, so I can't recommend.
I just did the upgrade via software update and everything went good.
Good to know.
what RME hardware are you using?
I will look into it.
-jeremiah
1: MBP M1 Max 64gb
The list is visible at the bottom of the post.
Ah yes I see…just after I hit send:) oops!
so presumably all this hardware including original babyface is working. A good sign.
I will investigate the Ventura upgrade.
For now I work just with headphones directly into the computer.
-Jeremiah
1: MBP M1 Max 64gb
10 (edited by waedi 2023-05-11 20:49:38)
Yes all works fine.
And I often use the computer without any interface, sometimes with a headphone.
Good luck !
Experiencing same issues with any driver; booted unit in Class Compliant mode and also experiencing same issues (playback is stuttery and unstable.)
Considering possibility this is a hardware issue.
-jeremiah
1: MBP M1 Max 64gb
