Topic: Using Two ARC with a RME UFX II and Setting Global Shortcuts
Hi everyone,
I am currently using an RME UFX II for my setup. Due to my work routine, I often have to move back and forth between the control room and the recording room. To streamline this process, I am considering using two ARC controllers to manage the UFX II. Is this a feasible setup?
If this isn't possible, I'd like to inquire about an alternative solution. Specifically, I'm interested in setting up global shortcuts for TotalMix. I'm looking for a way to directly invoke Snapshot even when the TotalMix window isn't active. So far, I've only found non-global shortcut settings like F4...F8 in "ARC & Key Command Settings..."
Any guidance on this would be greatly appreciated. Thank you!
