1 (edited by klangtueftler 2023-06-02 13:56:07)
Topic: FF400 driver stopped working on Macbook Pro M1
till 2 days ago the Macbook Pro M1 worked perfectly with the FF400, no problems with all those adapter cables.
Yesterday the green LED for a working connection between Mac and FF400 was not lit anymore.
I tried a lot also installing again and again till I realized by checking System and Library folders that none of the files from the pkg was installed - security is reduced as required -  and the installation of RME driver was allowed in settings.
Now I'm lost, have no music and no budget for a new rme interface
Any help appreciated!
Thanks for reading
regards
Michael
Edit: forgot to mention that the latest macOS Ventura 13.4 is installed and with that version came the info that RME driver may stop working with coming updates/versions
Re: FF400 driver stopped working on Macbook Pro M1
You can download Totalmix here and put it into the applications folder in your mac.
Check out if it can run and at least let you play music ?
https://www.rme-audio.de/downloads/tota … ac_183.zip
Oh, wow, thanks for that tip, it works.
Just do not understand how but that doesn't matter :-)
Thanks again,
all the best
Michael
Me neither.
Can you open the Fireface settings dialog ?
Also - check out the new Digicheck NG !
https://www.rme-audio.de/downloads/digi … _090b5.zip
Totalmix opens and works fine,
Fireface settings open also ok,
DigiCheck opens but displays nothing (FF400 selected)
You have to select specific channels.
