agotheridge wrote:Guessing -10, but I don't think it matters. If +4 is overloading the input of the amp, then try -10 or turn the volume to the amp down when at +4. Listen and trust your ears. You might just find hitting the front of your amp a little hot sounds better to your ears. If that sounds harsh, try -10. It's not like you are going to blow up your amp either way.
For our ears louder sounds always better, therefore the loudness war in the music industry.
So don't forget to compare the different reference levels at the same final listening level.
The difference between -10 dBV consumer level and +4 dBu studio level is 7,78 dBu.
At +4 dB studio level, you would need to reduce the volume at the amp by around 8 dB (rounded).
http://www.sengpielaudio.com/Rechner-db-volt.htm
It's surely difficult to compare quickly between those two levels.
I would request the specs of the analogue inputs from the manufacturer, or maybe even ask them whether +4 dBu is fine.
To work according to the specs might be easier to do.
