Topic: Aquired the UFX and UFX II and wondering which to keep?
So I bought a UFX used and it had no sound output. Seller was great and sent me a used UFX II but that would not power on. I obtained a new power supply for the UFX and it's in my setup and working. I'll get the UFX II repaired and then decide which one to keep.
I want to use either unit live with my macbook but also as a stand alone in case I have any computer trouble. I believe the unit holds 5 or 6 presets? Can you download a total mix set up with routing into the units to run standalone? I am setting up a mostly live and sometimes a recording setup for drums only and have Four situations:
1. Acoustic drums only with 4 channels live
2. Adat for 12 mics recording.
3. Electronic pads triggering superior drummer 3 live or recording. and the
4th option is Acoustic 4 channel triggering SD 3 in combination.
So should the computer go down can I just switch the saves presets and go with mics or my edrum module only as a preset? I need a click channel, Monitor in ear feed. I suppose I could get a simple rack digital mixer but thought it would be nice to use the RME for all situations and my in ear rig with stellar quality sound and have a simple small case to bring with me for any set up. Thanks for your insight.
