Topic: Main out B/T disengages on powering on/sample rate change/PH1/2 switch
I noticed a strange behavior in my ADI-2 Pro FS R (firmware version 265/117).
When I turn bass/treble on, it resets to off after standby, sample rate switch or toggling between main out and front PH1/2 out. The values themselves (gain, freq) are saved, it's just the B/T Enable setting that resets to "Off". And it does not matter which output is currently active, 1/2 or 3/4 − it always disengages B/T for 1/2 and not for 3/4.
After playing around a bit, I noticed that this behavior is observed when the "Load B/T with EQ preset" setting is on for output 1/2, even if the EQ itself is disabled. I think this behavior is wrong and counterintuitive.
I wonder if this is a bug that should be fixed. I have not noticed it before since I do not use the bass/treble adjustments so much, and came across this behavior accidentally when playing around with the B/T settings while using the dark volume screen at the same time, otherwise I probably would not have noticed this.
Re: Main out B/T disengages on powering on/sample rate change/PH1/2 switch
Maybe you cycle through very high sample rates during power on.
Watch the indication on the lower right corner of the display.
From the manual, page 16:
8.8 DSP Limitations
At sample rates 352.8 kHz and up the Bass, Treble and Loudness function is deactivated. The number of available EQ channels is reduced to 2 (1 x stereo). EQ can still be used with Analog Input, Main Output 1/2 or Phones Out 3/4, but only one of these.
At sample rates 705.6 kHz and up Crossfeed or EQ (1 x stereo) can be active, not both at the same time.
Yes, I am aware of the DSP limitations. The issue is not related to them since I use only 44.1 kHz. Besides, as I have pointed out, this behavior is there if the "Load B/T with EQ preset" setting is on for output 1/2, regardless of whether EQ is enabled or not for this output.
That has been explained here:
https://forum.rme-audio.de/viewtopic.ph … 40#p194840
I see. Thank you, Matthias, at least now I understand what is going on and how to work around this. I wouldn't say it is a big deal anyway wink
