Topic: Can I use the ADI-2 Pro FS R for quadrophonic playback from Reaper?
Hello!
I wonder if this is possible with the ADI-2 Pro FS R , to use the main outputs for speakers 1 & 2 and the headphones out for speakers 3 & 4.
Can the ADI-2 Pro FS R be a 4 Output Audio Interface for Reaper, or will I need the ADI-2 Pro SE for this?
2 (edited by KaiS 2023-08-14 06:03:41)
Re: Can I use the ADI-2 Pro FS R for quadrophonic playback from Reaper?
With fitting cables ADI-2’s headphone outputs can serve as line outs, e.g. to drive active speakers.
There’s no loss of quality, and nothing will break.
3 (edited by stingscloud 2023-08-15 02:16:02)
Thank you!
So this is then a separate DAC for 3 & 4?
How would this look in Reaper, is the ADI-2 Pro then an ASIO device with 4 outputs and 2 Inputs?
4 (edited by KaiS 2023-08-15 09:11:50)
On ADI-2 Pro 1/2 and 3/4 are completely separated audio paths with their own DSP and DAC.
In “Class Compliant Multi-channel mode” (see manual page 36ff, specially page 40) they appear as separate outputs in your PC.
Look at the block diagrams to select a basic “Mode” that fits to your demands.
With that setup in Class compliant multichannel mode, what amount of latency can I expect in reaper on a modern pc?
6 (edited by KaiS 2023-08-17 09:11:15)
A short one like 5 ms or better RTD if the PC is configured optimal.
