Regarding your comment "no computer nearby".
I am uncertain whether it is maybe still an option for you if you think about how long AES or ADAT cables can be.
Let's put my living room as an example.
On the one end I have my recording corner, on the other end/side the HiFi corner.
The recording corner is actually my work place for everything that I do with the computer:
Office, Internet, Recording, listning to music, gaming.
There I have UFX III as a recording interface and am using an ADI-2 Pro FS R BE as reference converter with all of its features.
Then I have a long ADAT cables from the recording interface (UFX III) going to the 2nd ADI-2 Pro FS R BE, which does all AD/DA in my HiFi Corner to all involved devices.
Recording Corner:
UFX III ---- ADI-2 Pro FS R BE
| ADAT (15+1=16m)
Oehlbach Optosel 4:1------ADI-2 Pro FS R BE
TV
BluRay
free
Either you get a recording interface and have the possibility to connect it to a computer.
If you use ADAT you can use up to 15m without issues, I have even another 1m on top behind the TOSLINK switcher.
If you would use AES then even around 100m or even more would be possible.
This way, you can make your Laptop or Desktop computer to a music player.
The best thing for me is, that I can remote control the MusicBee Player on Windows remote through Wireless using an Android app. Then I can play for example an Auto-Playlist (all at minimum 5-Star rated FLAC files) and skip or go back using the smartphone as remote.
But if you do not want/need a recording interface at all or to use your computer for music, then simply skip my idea, then KaiS solution is the most cost efficient for you and doesn't change anything in your setup. Then you also no not have to deal with TotalMix FX and routing ...
And older status, meanwhile a lot of devices changed, but this was the initial setup as described above:
https://www.tonstudio-forum.de/blog/Ent … her-EN-DE/
Some other views on it:
The actual setup how all fits into each other in Recording and HiFi Corner.
Do not look too much into the details, just to give you an impression, how nicely everything works together.
