Topic: Recording via Madi and virtual sound check playback questions
Hi there,
Just wanted to run a few things by you all regards recording live shows and virtual playback soundchecks.
I normally use a dedicated madi recording pc which i hire in, but ive heards lots of good things about rme, I thought I would try them out and buy my own system.
I normally use a digico sd7 or d5 and record all the shows via madi and also use these recordings for virtual soundchecks and also trying new things in the mix without having to have the band on stage.
Ill be using a macpro and also I presume I will also just need 2x hdspe madi 128 i/o cards as need to record and play back 96 channels. Im looking at tracking in logic studio.
Anyone have any thoughts / comments / ideas of this set up or better ones?
Also what would you say minimum spec of the macpro should be?
