It should ! By sending sync it should include the Midi-clock ( =BpM) along with start stop message.
Check the Sequencer settings for having receiving midi-clock enabled.
Some devices have this in the menu, clock internal or external.
From page 12 :
Tempo
Choose between internal or external clock.
To select the clock source go to “Tempo”, press the encoder, choose “INT” “EXT” or “MIDI CLK” and press the encoder again. This parameter is stored globally in the global configuration not in the project file.
Select Midi-clk, not ext !
I used this user manual, hopefully it's the right one ?
https://winter-modular.com/wp-content/u … V1.3.0.pdf
