Topic: What USB pci card\chipset for Fireface 802
Hello there, I got a Fireface 802 and I was wondering if I should buy a pci USB 2 card to connect it, instead of my motherboard's usb inputs (Asus Prime Z370-A).
Do I need to get a seperate pci USB 2 card and which one?
Thank you very much!!!
2 (edited by vinark 2023-12-10 16:56:54)
Re: What USB pci card\chipset for Fireface 802
No not if the onboard works. If it does not work straight away first try the legacy firewire driver (google its a microsoft download and read the instruction). My onboard firewire always worked perfectly.
Thank you but its a USB devise. Despite the name.  Any ideas about usb?
Ooooops, then even more so, since you have an Intel based mobo, the usb2 ports from intel are perfect. Also from experience...
If you do get issues just make sure it is in unshared port. You can check that in device Manager if you choose view on connection
