Topic: 12Mic not recognizing double speed with 96k madi frame
my setup consists of UFX III, 12Mic and Ferrofish Pulse 16MX connected via MADI.
I have DAW projects of different sample rates, single and double speed.
MADI optical is configured on all devices to use a MADI Frame of 96k.
My understanding is, that then each device should be able to detect whether sample rate is single or double speed.
In this setup the UFX III is clock master.
The Ferrofish is recognizing sample rate changes between eg 44.1 kHz and 88.2 kHz (depending on what DAW project I choose).
Sadly the 12Mic doesn´t follow the sample rate.
I have always to change the sample rate manually, but only for the 12Mic. Ferrofish works automatically,
Could you kindly tell whats the problem?
I would really be glad, if the 12Mic could follow the sample rate automatically like the Ferrofish does.
I hope this is possible, but how???
Thanks in advance
