Topic: Gain not actually set as indicated upon snapshot loading
I have a weird bug. I've got a snapshot that turns on 48V and sets a gain on my LEFT input, among a few other little things. It works fine, but the signal coming from the left input (an LDC) is very low, it barely moves the meter, not at all correct with the set gain at 27. If I just move the gain slider down to 24, then back up to 27, I get the expected result. It's as if the gain setting isn't quite set to the actual interface correctly, just the gui knob in totalmix.
Another action that fixes it is moving the gain slider of the RIGHT input that is muted and has no 48V enabled.
Yet another action that fixes it: turning on 48V on the right channel, despite not having it connected to anything. If I save the snapshot like this, it will also work upon loading again directly, without touching gain knobs or 48V. So this is what I do for now.
Latest driver. Any idea why this is? I haven't always had this issue.
ps: I tried re-saving the snapshot but it doesn't help.
