Topic: [Solved] Fireface 800 matrix routing help
I'm trying to set up my Babyface Pro as a master and Fireface 800 as the slave to increase the number of inputs I have.
Clock mode: Autosync
Preferred Sync Ref / input statys: ADAT 1
Store: Check
Now I'm trying to figure out how to do the routing in the Totalmix Matrix, but I can't seem to find a guide that shows me the current TM version, so I'm a bit stuck.
Is this correct?
An 7/8 to ADAT 1/2
An 9/10 to ADAT 3/4
2 (edited by waedi 2023-12-25 17:44:27)
Re: [Solved] Fireface 800 matrix routing help
Yes
An 7/8 input to ADAT 1/2 output
An 9/10 input to ADAT 3/4 output
In the Babyface Totalmix in the Adat input channels 1 to 4 the four mics of the FF800 should arrive.
I tried the routing and saved the settings by clicking "Store current State into Device / Flash Mixer". But there is no signal coming through when I try the different outputs.
https://drive.google.com/file/d/1usqK4k … share_link
I notice that the Babyface Pro Totalmix shows AS 1/2 and then ADAT 3/4 instead of beginning with ADAT 1/2. Is this something I need to consider?
Also, the host-led is red.
Any suggestions?
4 (edited by waedi 2023-12-26 02:59:26)
Try this :
https://i.ibb.co/BGbLHLT/TMFX-matrix.jpg
In the Babyface the AS12 stands for Adat or SPDIf 1/2, in the Fireface settings you can activate SPDIF, as you don't use it, nothing to worry about.
5 (edited by karl.michelson 2023-12-25 22:50:58)
Great stuff! Seems to work as intended. Thank you very much.
Glad you can work
