Topic: [Solved] solo problem between logic and totalmix
I have a Fireface800 connected to my Logic computer (Lcomp, a MacPro from 2010) which serves as a sound generating machine only, to the main Protools computer (PTcomp, also a Mac Pro from 2010). Midi signals go from PTcomp to Lcomp, and the audio from the instruments in Lcomp are routed back to PTcomp via the Fireface800 (FF800) connected to Lcomp via the ADAT outs from the FF800 to a 192Digital connected to PTcomp. This setup works perfectly.
However a very strange thing occurs.
If I have a number of instruments in Lcomp and I want to solo say the first one then I have to mute all the others because when I solo instrument one all others are indeed muted but so is the instrument one itself, no sound at all comes through anymore. Also, when I solo all instruments no sound at all comes through anymore whereas they should all still sound. There is one exception, namely the instrument with stereo out from logic assigned as output which goes to Main in totalmix. That instrument when soloed in logic does indeed still sound and thus can be soloed.
The routing in the FF800 is the so-called simple DAWmode.
Thanks for taking a look!
Cheers, Bob.
